It is currently Tue Aug 12, 2025 10:15 am
PostPosted: Fri Jan 29, 2010 2:16 am
Last Name: Renick
City: Mount Shasta
State: ca
Zip/Postal Code: 96067
Country: us
I would like to make some solid molds for side bending with a heating blanket. 3/4" MDF is a bit cheaper then the cheapest suitable plywood. Will I have problems with it when it gets hot?
Rob
http://shastaguitar.com/
http://www.kalimbakit.com/
PostPosted: Fri Jan 29, 2010 7:28 am
First name: Tom
Last Name: West
State: Nova Scotia
Rob: I've used MDF for forms and they have worker out fine for me.The only problem I've seen is that the MDF is less stable then ply in that it takes up and releases moisture easier. This has not resulted in any problems for me. You may want to put three through bolts in your molds to make sure you don't get seperation. Good luck with your project.
Tom
PostPosted: Fri Jan 29, 2010 7:54 am
First name: Coe
Last Name: Franklin
City: Decatur
Tom,
MDF works fine for me, too.
The only drawbacks are it`s one dusty mess in the fabrication stages (which is only temporary), and the molds or forms are relatively heavy.
There is also a myriad of other uses for it when making the various jigs and fixtures that I`ve made so far.
Go ahead and invest in a sheet, and you`ll more than likely go for another.
For the price, you can`t go wrong.
For your well being, use breathing protection. The stuff will load you up and stick around for a few days. [xx(]
Coe Franklin
PostPosted: Fri Jan 29, 2010 8:10 am
you can get a few off them , the water will make them spongey after a few uses so be careful
PostPosted: Fri Jan 29, 2010 8:50 am
Last Name: A
You can always seal them to protect form the water damage. A little shellac maybe ?
PostPosted: Fri Jan 29, 2010 9:01 am
the heat makes the shellac bubble
PostPosted: Fri Jan 29, 2010 9:12 am
I really prefer Baltic birch. I used to use particle board and coat it with polyester resin, but like ply better. What's a few bucks compared to the effort to make the mould?
PostPosted: Fri Jan 29, 2010 9:47 am
First name: William
Last Name: Snyder
City: Brooklyn
The standard MDF you get from the home depot, etc. is also made with formaldehyde (a known carcinogen) and I believe it releases a bit of it when it's heated. They do make MDF without formaldehyde (this stuff is also a little harder/more homogenous throughout and would probably hold up a little better) but you'd probably have to order it. I'd stick to ply.
PostPosted: Fri Jan 29, 2010 10:16 am
I've been using fibercore for most of my molds and jigs. It' MDF with a layer of Baltic Birch on either side. It's been very stable, really flat, and easy to rout and shape.
PostPosted: Fri Jan 29, 2010 10:32 am
Terence, where do you get this Fibercore? Sounds appealing.
The problem with MDF is that, even if it is extremely stable, it will swell and lose shape if water is dropped on the material. And IME warm water will get through any sealer, shellac, oil or urethane.
Formaldehyde is present in the glue used for most plywoods.
Laurent Brondel
West Paris, Maine - USA
PostPosted: Fri Jan 29, 2010 11:08 am
Last Name: Renick
City: Mount Shasta
State: ca
Country: us
Thanks for the answers.
Now that I have these answers, perhaps the better question would have been how do I seal them for better longevity. Titebond 3 has some amazing heat and moisture resistance, not sure if it can handle that much heat though. I can thin that to help seal it, or just be careful.
I really hate being cheap, it is only $12/ sheet difference from the ply, but all those $20 dollar expenses really add up, I will use 2 sheets to make 2 bending and body molds. (The GAL 20's Gibson LO and the Antes parlor plans are under way) I will have material left for other jigs. I have used MDF for jigs in the past and it is easy to work with. My budget is really limited for this project, and if these molds wear out from use, then I am happy I have made that many guitars.
The hardwood supplier I am using has the fiber core product as well, I have some in 1/4" left from some other projects. It is a nice product, I have used it to make the templates to start these molds.
Thanks again, the material will be delivered today and the molds will be underway.
Rob
PostPosted: Fri Jan 29, 2010 11:46 am
First name: Matthew
Last Name: Dollinger
City: Beaverton
State: Oregon
Zip/Postal Code: 97005
Would it be recommended to use an epoxy resin to seal it up? You would never have to worry about moisture, but heat may not be nice to it. I have thought a few times about getting sheets of counter top material and gluing that on, but again wonder about heat resistance.
For mine, I have bent and welded a metal form and cover it with foil to protect the wood from the aging steel. Works great but wasn't the cheapest or easiest to make either.
Matthew
PostPosted: Fri Jan 29, 2010 12:22 pm
Rob, I've made my molds from MDF and used the HVAC foil tape to seal. Works for me. Tony
Tony Flippo
PostPosted: Fri Jan 29, 2010 12:58 pm
Last Name: Renick
City: Mount Shasta
State: ca
Country: us
Tony,
Perfect, I even have a roll in the shop, I love solutions that involve stuff already on my shelf. Do you overlap the edges? If you do does the tape thickness matter in the flatness of the mold surface? Two layers could certainly cover the seems with no unevenness.
Do you have pictures of your jig with a side in it? I am wondering how the 4 carriage bolts are used in the bending process.
Thanks for the tip.
Rob
PostPosted: Fri Jan 29, 2010 2:38 pm
comfyfoot wrote:
Tony,
Thanks for the tip.
Rob
Rob, I do overlap the edges a small amount. The thickness of the foil is only .002” so I don’t bother taking into account the thickness – what’s a few thousandths between friends? (that may cause some churn in the left brain camp).
It is based on the Everett style mold, but without any springs – I just push carefully by hand and lock down with the carriage bolts. Homemade and cheap enough not worry about messing them up. The blocks are made of pine 2x4s and they also have foil tape on the side facing the wood. All materials from HD.
This side is just for demonstration purposes with no heat blanket. I usually sprits sides with water and wrap in tin foil then place heat blanket on top These sides are for a lacewood dread I got off ebay that I’m going to reshape into a Payne SJ.
Tony Flippo
PostPosted: Fri Jan 29, 2010 3:14 pm
One of the local lumbar yards carries it here. I bought some by mistake a few years ago thinking it was birch plywood and really liked it for some jigs mainly because it is so flat and easy to shape with sanders/routers etc. The MDF will split easily if you drive a sheetrock screw into it without predrilling. It's also pretty heavy which can be a good thing sometimes. Here's a circle routing jig made from it.
PostPosted: Fri Jan 29, 2010 3:23 pm
First name: duh
Last Name: Padma
Is MDF suitable for side bending molds...well thats a good question...seems others have answered to it so I wonder if MDF is suitable for sides and backs.
Ya can you dig it..a MDF build...finished with duck tape...by god it be beautiful. laughing6-hehe
Icu
the
Padma
PostPosted: Fri Jan 29, 2010 4:30 pm
Last Name: Renick
City: Mount Shasta
State: ca
Country: us
Icu
the
Padma
I am not sure about the duct tape, I think I would dip the whole thing in that liquid rubber tool handle stuff, or perhaps we can do a burst finish with the rubber coating going into some fine silver duct tape. The binding could be a few layers of colored electrical tape. I can dig it, but it may require plenty of Northern Cali's finest to actually make it beautiful.
Rob
PostPosted: Sat Jan 30, 2010 2:21 am
First name: William
Last Name: Snyder
City: Brooklyn
This is true. However MDF contains far more formaldehyde resins (typically 9% by weight) than plywood. To quote the EPA, "...Medium density fiberboard contains a higher resin-to-wood ratio than any other UF pressed wood product and is generally recognized as being the highest formaldehyde-emitting pressed wood product." In addition, it has become fairly easy to find plywood that emmits little to no formaldehyde.
PostPosted: Sat Jan 30, 2010 8:33 am
Last Name: Neal
City: Arcadia
State: ok
Zip/Postal Code: 73007
I wonder if you could paint them with engine paint? Its heat resistant to 1,000 degree F
PostPosted: Sat Jan 30, 2010 8:37 am
First name: Big
Last Name: Jim
Was talking to a Cabinet customer of mine yesterday I mentioned that I would like some molds made from his cnc router from mdf but i was concerned it would have trouble with the wet application . He said not to worry he keeps MOISTURE PROOF mdf in stock. So , all I have to do is supply cad drawings and he will router my molds for me at a VERY good price bliss [:Y:] [:Y:] bliss
PostPosted: Sat Jan 30, 2010 9:20 am
First name: Matt
Last Name: Rispoli
State: NJ
I am very cheap but I still say plywood if it is only going to be a few dollars difference.
PostPosted: Sat Jan 30, 2010 9:28 am
I use mdf on some of my molds. To cut down on weight, you can just use every other layer and space them apart with spacers made from the scrap pieces that are left from cutting out the shape. The 1/2" or 3/4" gap between each layer does not cause any problems with the bend.
I have never had any problems with moisture. Apparently some folks use way more moisture than I do. I simply spritz the side that I am bending, wipe off the excess, wrap the side in aluminum foil, and sandwich the side and the bending blanket between the SS slats. The only thing touching the form is the lower slat in the sandwich. No moisture ever gets to the mold. This heating blanket method with solid forms is much easier for me than the Fox style bender that I built years ago. I like having the support under the full length of the sides, rather than the metal rods going across.
I can't comment about the formaldehyde, but I will do some research for my own benefit. I like the idea of the foil tape, but my forms have suffered no problems resulting from glue failure caused by the heat.
The forms are really easy to make. Cut and finish one layer to the proper shape, and use that piece as a pattern for the other layer to run on the flush cut router bit. Of course you cut each layer on the bandsaw to within about 1/4" of the right shape. Do the routing outside, and have a dumpster rented to haul away the pile of dust you will create. :)
I will probably use Todd's idea above for my next form. I like the idea, as well as the material choice. I will still leave every other layer out with a spacer in its place.
PostPosted: Sat Jan 30, 2010 10:04 am
First name: Big
Last Name: Jim
Icu
the
Padma
Rob
I say spray that sucker with Rino Tuff Bed Liner , she will never wear out laughing6-hehe
Users browsing this forum: No registered users and 54 guests
